开发环境搭建
获取TinaSDK源码
查看上面源码工具文档手册,下载TinaSDK源码:
Tina-SDKV2.0源码网盘链接:https://pan.baidu.com/s/13uKlqDXImmMl9cgKc41tZg?pwd=qcw7 T113-Pro开发板扩展补丁: https://github.com/DongshanPI/100ASK_T113-Pro_TinaSDK
上传到ubuntu,创建文件夹用来保存源码:
├── tina-d1-h.tar.bz2.00
├── tina-d1-h.tar.bz2.01
├── tina-d1-h.tar.bz2.02
├── tina-d1-h.tar.bz2.03
├── tina-d1-h.tar.bz2.04
├── tina-d1-h.tar.bz2.05
├── tina-d1-h.tar.bz2.06
├── tina-d1-h.tar.bz2.07
└── tina-d1-h.tar.bz2.08
0 directories, 9 files
查看所有文件MD5校验值:
确保校验值对上。否则需要重新上传。
解压源码:
等待一段时间,即可解压完成。
├── tina-d1-h
1 directory, 9 files
ubuntu@ubuntu1804:~/Tina_SDK$ mv tina-d1-h ../
获取扩展支持仓库,然后加以应用:
ubuntu@ubuntu1804:~$ git clone https://github.com/DongshanPI/100ASK_T113s3-Industrial-Devkit_TinaSDK
ubuntu@ubuntu1804:~$ cd 100ASK_T113s3-Industrial-Devkit_TinaSDK/
ubuntu@ubuntu1804:~/100ASK_T113s3-Industrial-Devkit_TinaSDK$ ls
device lichee package prebuilt README.md target
ubuntu@ubuntu1804:~/100ASK_T113s3-Industrial-Devkit_TinaSDK$ git submodule update --init
ubuntu@ubuntu1804:~/100ASK_T113s3-Industrial-Devkit_TinaSDK$ cp ./* -rfvd ~/tina-d1-h
编译固件之前,先安装一些依赖,否则编译会报错:
编译出固件
进入源码目录,执行:
ubuntu@ubuntu1804:~$ cd tina-d1-h/
You're building on Linux
Lunch menu... pick a combo:
1. d1-h_nezha_min-tina
2. d1-h_nezha-tina
3. d1s_cvbs-tina
4. d1s_nezha-tina
5. t113_100ask-tina
Which would you like? [Default t113_100ask]: 5
TINA_TARGET_ARCH=arm
TARGET_PRODUCT=t113_100ask
TARGET_PLATFORM=t113
TARGET_BOARD=t113-100ask
TARGET_PLAN=100ask
TARGET_BUILD_VARIANT=tina
TARGET_BUILD_TYPE=release
TARGET_KERNEL_VERSION=5.4
TARGET_UBOOT=u-boot-2018
TARGET_CHIP=sun8iw20p1
clean buildserver
[1] 24251
#### make completed successfully (01:16 (mm:ss)) ####
打包成功后,镜像文件保存在/home/ubuntu/tina-d1-h/out/t113-100ask/tina_t113-100ask_uart3.img
烧录固件
把镜像文件传到PC端,打开全志线刷工具 AllwinnertechPhoeniSuit,找到PhoenixSuit.exe ,双击运行:
image-20240709111952653
选择一键刷机:
image-20240709112026606
找到镜像路径,选择全盘擦除升级:
image-20240709112117543
点击完成后,不需要其他界面操作,这时拿起已经连接好的开发板,先按住 FEL 烧写模式按键,之后按一下 RESET 系统复位键,就可以自动进入烧写模式并开始烧写。
image-20240709112322292
串口打印信息,如下:
insmod: can't insert '/lib/modules/5.4.61/xr829.ko': Operation timed out
------run rc.final file-----
: values=on
------run profile file-----
_____ _ __ _
---------------------------[ 9.916991] file system registered
Mon Feb 6 00:00:00 GMT 2023
nodev debugfs
root@TinaLinux:/# [ 9.941016] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[ 11.008518] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
[ 11.024290] read descriptors
[ 11.027508] read strings
[ 11.254062] android_work: sent uevent USB_STATE=CONNECTED
[ 11.471404] configfs-gadget gadget: high-speed config #1: c
[ 11.477684] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.498279] android_work: sent uevent USB_STATE=DISCONNECTED
[ 11.555679] android_work: sent uevent USB_STATE=CONNECTED
root@TinaLinux:/#
