开发环境搭建
1.获取TinaSDK5源码
- 打开Tina5-SDK基础包获取:https://forums.100ask.net/t/topic/7393
- 通过百度网盘下载,大小约3.3G,名称为tina5sdk-bsp-50ae436fe556be2253856af283b1e094.tar.gz 下载完成后通过网络等方式拷贝到虚拟机目录下。
- 获取T113i扩展补丁包:https://github.com/DongshanPI/T113i_DevKitF_Tina5SDK/
在虚拟机上,打开下载好的ubuntu镜像。 拉取扩展补丁:
ubuntu@ubuntu1804:~$ git clone https://github.com/DongshanPI/T113i_DevKitF_Tina5SDK.git
ubuntu@ubuntu1804:~$ tar -xvf tina5sdk-bsp-50ae436fe556be2253856af283b1e094.tar.gz
ubuntu@ubuntu1804:~$ cd tina5sdk-bsp
ubuntu@ubuntu1804:~/tina5sdk-bsp$ git clone https://e.coding.net/weidongshan/tina5/buildroot.git
ubuntu@ubuntu1804:~/tina5sdk-bsp$ git clone https://e.coding.net/weidongshan/tina5/openwrt.git
ubuntu@ubuntu1804:~/tina5sdk-bsp$ git clone https://e.coding.net/weidongshan/tina5/platform.git
ubuntu@ubuntu1804:~/tina5sdk-bsp$ ls
进入源码根目录tina5sdk-bsp/
,拷贝扩展补丁:
ubuntu@ubuntu1804:~/tina5sdk-bsp$ cp ~/T113i_DevKitF_Tina5SDK/* -rfvd .
2.编译固件
在Ubuntu上,进入源码根目录tina5sdk-bsp
①先执行 source build/envsetup.sh
初始化环境变量;
②接着执行 ./build.sh
选择开发板选项。
- platform : linux
- linux_dev : buildroot
- ic : t113_i
- board : evb1_auto
- flash : default
ubuntu@ubuntu1804:~/tina5sdk-bsp$ source build/envsetup.sh
NOTE: The SDK(/home/ubuntu/tina5sdk-bsp) was successfully loaded
load openwrt... ok
load buildroot,bsp...ok
Usage: build.sh [args]
build.sh - default build all
build.sh clean - clean all
build.sh pack - pack firmware
Usage: pack [args]
ubuntu@ubuntu1804:~/tina5sdk-bsp$ ./build.sh
All available platform:
0. android
1. linux
Choice [android]: 1
All available linux_dev:
0. bsp
1. buildroot
2. openwrt
Choice [bsp]: 1
All available ic:
0. t113_i
1. t113_s4
Choice [t113_i]: 0
All available board:
0. evb1
1. evb1_auto
2. evb1_auto_nand
3. evb1_auto_nor
Choice [evb1]: 1
All available flash:
0. default
1. nor
Choice [default]: 0
选择完,按下Enter
键之后,会出现报错。
Choice [default]: 0
INFO: kernel relative recovery defconfig: ../../../../../device/config/chips/t113_i/configs/evb1_auto/linux-5.4/config-5.4-recovery
INFO: kernel absolute recovery defconfig: /home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/configs/evb1_auto/linux-5.4/config-5.4-recovery
INFO: Prepare toolchain ...
INFO: kernel defconfig: generate /home/ubuntu/tina5sdk-bspout/t113_i/kernel/build/.config by /home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/configs/evb1_auto/linux-5.4/config-5.4
make: Entering directory '/home/ubuntu/tina5sdk-bspkernel/linux-5.4'
make[1]: Entering directory '/home/ubuntu/tina5sdk-bspout/t113_i/kernel/build'
GEN Makefile
*** Default configuration is based on '../../../../../device/config/chips/t113_i/configs/evb1_auto/linux-5.4/config-5.4'
# No change to .config
make[1]: Leaving directory '/home/ubuntu/tina5sdk-bspout/t113_i/kernel/build'
make: Leaving directory '/home/ubuntu/tina5sdk-bspkernel/linux-5.4'
make: Entering directory '/home/ubuntu/tina5sdk-bspbuildroot/buildroot-201902'
GEN /home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/buildroot/Makefile
Config.in.legacy:1769:warning: choice value used outside its choice group
# configuration written to /home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/buildroot/.config
make: Leaving directory '/home/ubuntu/tina5sdk-bspbuildroot/buildroot-201902'
INFO: buildroot defconfig is sun8iw20p1_t113_defconfig
INFO: clean buildserver
INFO: prepare_buildserver
options :
INFO: build linuxdev ...
INFO: chip: sun8iw20p1
INFO: platform: linux
INFO: kernel: linux-5.4
INFO: board: evb1_auto
INFO: output: /home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot
INFO: don't build dtbo ...
INFO: build arisc
find: '/home/ubuntu/tina5sdk-bspbrandy/brandy-2.0/spl': No such file or directory
find: '/home/ubuntu/tina5sdk-bspbrandy/dramlib': No such file or directory
INFO: build_bootloader: brandy_path=/home/ubuntu/tina5sdk-bspbrandy/brandy-2.0
INFO: skip build brandy.
INFO: build kernel ...
Makefile:681: arch//Makefile: No such file or directory
make: *** No rule to make target 'arch//Makefile'. Stop.
ERROR: build Failed
INFO: build kernel failed
加上 -d
参数,强行编译,就不会出现报错了。
ubuntu@ubuntu1804:~/tina5sdk-bsp$ ./build.sh -d
options :
INFO: build arisc
Building kernel
GEN Makefile
DTC arch/arm/boot/dts/board.dtb
CALL /home/ubuntu/tina5sdk-bspkernel/linux-5.4/scripts/atomic/check-atomics.sh
CALL /home/ubuntu/tina5sdk-bspkernel/linux-5.4/scripts/checksyscalls.sh
CHK include/generated/compile.h
Kernel: arch/arm/boot/Image is ready
Building modules, stage 2.
MODPOST 6 modules
Kernel: arch/arm/boot/zImage is ready
Kernel: arch/arm/boot/uImage is ready
Exportable Squashfs 4.0 filesystem, xz compressed, data block size 131072
compressed data, compressed metadata, compressed fragments, no xattrs
duplicates are removed
Filesystem size 56902.63 Kbytes (55.57 Mbytes)
38.88% of uncompressed filesystem size (146336.84 Kbytes)
Inode table size 54158 bytes (52.89 Kbytes)
23.54% of uncompressed inode table size (230025 bytes)
Directory table size 70804 bytes (69.14 Kbytes)
48.95% of uncompressed directory table size (144657 bytes)
Number of inodes 6686
Number of files 5571
Number of fragments 397
Number of symbolic links 813
Number of device nodes 0
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 302
Number of uids 1
root (0)
Number of gids 1
root (0)
INFO: pack rootfs ok ...
INFO: build Tina OK.
等待一段时间,编译成功后,执行 ./build.sh pack
进行打包。
ubuntu@ubuntu1804:~/tina5sdk-bsp$ ./build.sh pack
options :
INFO: packing firmware ...
INFO: /home/ubuntu/tina5sdk-bspout/t113_i/common/keys
copying tools file
copying configs file
copying product configs file
linux copying boardt&linux_kernel_version configs file
ls: cannot access '/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/configs/evb1_auto/linux-5.4/env*': No such file or directory
Use u-boot env file:
Warning: u-boot env file '' not exist! use file in default directory other than 'evb1_auto' directory
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/aultls32.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/aultools.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot_package.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot_package.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot_package_nor.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/cardscript.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/cardscript_secure.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/cardtool.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/diskfs.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/dragon_toc.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/env-recovery.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/env.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/env_ab.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/env_burn.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/env_dragon.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/env_nor.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/esm.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/image.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/image_crashdump.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/image_linux.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/image_nor.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/parameter.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/split_xxxx.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sunxi.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sw-subimgs-ab-rdiff.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sw-subimgs-ab.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sw-subimgs-recovery.cfg
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sys_config.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sys_partition-recovery.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sys_partition.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sys_partition_ab.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sys_partition_dump.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sys_partition_nor.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sys_partition_private.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sysrecovery.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/toc0.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/toc0_ft.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/toc0_nand.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/toc0_sdcard.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/toc0_ufs.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/toc1.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/usbtool.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/usbtool_crash.fex
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/usbtool_test.fex
copying boot resource
copying boot file
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/bin/boot0_nand_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot0_nand.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/bin/boot0_sdcard_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot0_sdcard.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/bin/boot0_spinor_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot0_spinor.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/bin/fes1_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/fes1.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/bin/u-boot-sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/u-boot.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/bin/optee_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/optee.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i//bin/boot0_nand_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot0_nand.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i//bin/boot0_sdcard_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot0_sdcard.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i//bin/boot0_spinor_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot0_spinor.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i//bin/fes1_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/fes1.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i//bin/u-boot-sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/u-boot.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i//bin/optee_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/optee.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/configs/evb1_auto/bin/amp_rv0.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/amp_rv0.fex'
'/home/ubuntu/tina5sdk-bspdevice/config/chips/t113_i/configs/evb1_auto//bin/amp_rv0.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/amp_rv0.fex'
copying boot file 2.0
'/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/arisc' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/arisc.fex'
'/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/sunxi.dtb' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sunxi.fex'
'/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/boot0_nand_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot0_nand.fex'
'/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/boot0_sdcard_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot0_sdcard.fex'
'/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/boot0_spinor_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/boot0_spinor.fex'
'/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/fes1_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/fes1.fex'
'/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/sboot_sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sboot.bin'
'/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/u-boot-sun8iw20p1.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/u-boot.fex'
'/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/vmlinux.tar.bz2' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/vmlinux.fex'
copying arm secure boot file
copying additional files
handle partition_size
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/.uboot.dtb.dts.tmp: Warning (spi_bus_reg): /soc@29000000/spi@4025000/spi_board0: SPI bus unit address format error, expected "0"
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/.uboot.dtb.dts.tmp:661.15-670.6: Warning (spi_bus_reg): /soc@29000000/spi@4025000/spi_board0: SPI bus unit address format error, expected "0"
'/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/temp_ubootnodtb.bin' -> '/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/u-boot.fex'
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/.uboot.dts: Warning (spi_bus_reg): /soc@29000000/spi@4025000/spi_board0: SPI bus unit address format error, expected "0"
/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/buildroot/.sunxi.dts: Warning (alias_paths): /aliases: aliases property name must include only lowercase and '-'
update optee
do not set LINUX_DTBO_FILE
pack boot package
content_count=3
2:LICHEE_REDUNDANT_ENV_SIZE:0x20000
--redundant env data size 0x20000---
verity not supported yet
packing for linux
normal
commit : f7388902e9-dirty
mbr count = 4
partitation file Path=/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sys_partition.bin
mbr_name file Path=/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/sunxi_mbr.fex
download_name file Path=/home/ubuntu/tina5sdk-bspout/t113_i/evb1_auto/pack_out/dlinfo.fex
mbr size = 16384
mbr magic softw411
disk name=boot-resource
disk name=env
disk name=env-redund
disk name=boot
disk name=rootfs
disk name=riscv
disk name=private
disk name=UDISK
this is not a partition key
update_for_part_info 0
crc 0 = fd3908da
crc 1 = 68845987
crc 2 = d32ac21
crc 3 = 988ffd7c
MBR addr = 0x8000,logic_offset = 0xa000 GPT:boot-resource: 12000 1a685
MBR addr = 0x10686,logic_offset = 0xa000 GPT:env : 1a686 1ae85
MBR addr = 0x10e86,logic_offset = 0xa000 GPT:env-redund : 1ae86 1b685
MBR addr = 0x11686,logic_offset = 0xa000 GPT:boot : 1b686 24005
MBR addr = 0x1a006,logic_offset = 0xa000 GPT:rootfs : 24006 224005
MBR addr = 0x21a006,logic_offset = 0xa000 GPT:riscv : 224006 224805
MBR addr = 0x21a806,logic_offset = 0xa000 GPT:private : 224806 22c805
MBR addr = 0x222806,logic_offset = 0xa000 GPT:UDISK : 22c806 ffffffde
gpt_head->header_crc32 = 0xc0b73d8e
GPT----part num 8---
gpt_entry: 128
gpt_header: 92
update gpt file ok
update mbr file ok
temp = 40960
mbr count = 4 total_sectors = 15269888 logic_offset = 40960 media = 0
mbr size = 16384
mbr magic softw411
disk name=env
disk name=boot
disk name=rootfs
disk name=riscv
disk name=private
disk name=UDISK
crc 0 = fd3908da
crc 1 = 68845987
crc 2 = d32ac21
crc 3 = 988ffd7c
MBR addr = 0x222806,logic_offset = 0xa000 GPT:UDISK : 22c806 e8ffde
gpt_head->header_crc32 = 0x5ab3941c
gpt_entry: 128
gpt_header: 92
update gpt file ok
update mbr file ok
/home/ubuntu/tina5sdk-bsptools/pack/pctools/linux/eDragonEx/
Begin Parse sys_partion.fex
FilePath: boot-resource.fex
FilePath: env.fex
FilePath: env.fex
FilePath: boot.fex
FileLength=912800Add partion rootfs.fex ROOTFS_FEX000000
FilePath: rootfs.fex
FileLength=b20d850Add partion amp_rv0.fex AMP_RV0_FEX00000
FilePath: amp_rv0.fex
FileLength=29eb8BuildImg 0
264M /home/ubuntu/tina5sdk-bspout/t113_i_linux_evb1_auto_uart0.img
pack finish
打包成功后,镜像文件保存在 tina5sdk-bspout/t113_i/evb1_auto/buildroot/t113_i_linux_evb1_auto_uart0.img
ubuntu@ubuntu1804:~/tina5sdk-bspout/t113_i/evb1_auto/buildroot$ ls -la
total 825068
drwxrwxr-x 4 ubuntu ubuntu 4096 7月 16 18:10 .
drwxrwxr-x 4 ubuntu ubuntu 4096 7月 16 18:10 ..
-rw-rw-r-- 1 ubuntu ubuntu 6 7月 16 18:07 arisc
-rwxrwxr-x 1 ubuntu ubuntu 12985488 7月 16 18:07 bImage
-rw-rw-r-- 1 ubuntu ubuntu 66 7月 16 18:07 .board.dtb.d.dtc.tmp
-rw-rw-r-- 1 ubuntu ubuntu 79218 7月 16 18:07 .board.dtb.dts.tmp
-rw-rw-r-- 1 ubuntu ubuntu 40960 7月 16 16:31 boot0_mmc_car_fastboot_sun8iw20p1.bin
-rw-rw-r-- 1 ubuntu ubuntu 45056 7月 16 16:31 boot0_mmcfastboot_sun8iw20p1.bin
-rw-rw-r-- 1 ubuntu ubuntu 49152 7月 16 16:31 boot0_nand_car_fastboot_sun8iw20p1.bin
-rw-rw-r-- 1 ubuntu ubuntu 53248 7月 16 16:31 boot0_nandfastboot_sun8iw20p1.bin
-rw-rw-r-- 1 ubuntu ubuntu 49152 7月 16 16:31 boot0_nand_sun8iw20p1.bin
-rw-rw-r-- 1 ubuntu ubuntu 40960 7月 16 16:31 boot0_sdcard_sun8iw20p1.bin
-rw-rw-r-- 1 ubuntu ubuntu 32768 7月 16 16:31 boot0_spinor_sun8iw20p1.bin
-rw-rw-r-- 1 ubuntu ubuntu 9512960 7月 16 18:07 boot.img
-rw-rw-r-- 1 ubuntu ubuntu 4924 7月 16 18:07 .buildconfig
drwxrwxr-x 7 ubuntu ubuntu 4096 7月 16 18:07 buildroot
-rw-rw-r-- 1 ubuntu ubuntu 127053 7月 16 18:07 .config
lrwxrwxrwx 1 ubuntu ubuntu 18 7月 16 18:07 dist -> lib/modules/5.4.61
-rwxrwxr-x 1 ubuntu ubuntu 168392 7月 16 18:07 dtc
-rw-rw-r-- 1 ubuntu ubuntu 21152 7月 16 16:31 fes1_sun8iw20p1.bin
drwxrwxr-x 3 ubuntu ubuntu 4096 7月 16 18:07 lib
-rw-rw-r-- 1 ubuntu ubuntu 4000287 7月 16 18:07 rootfs.cpio.gz
-rw-r--r-- 1 ubuntu ubuntu 186701904 7月 16 18:07 rootfs.ext4
-rw-r--r-- 1 ubuntu ubuntu 58269696 7月 16 18:08 rootfs.squashfs
-rw-rw-r-- 1 ubuntu ubuntu 86446080 7月 16 18:08 rootfs.ubifs
-rw-rw-r-- 1 ubuntu ubuntu 86016 7月 16 16:31 sboot_sun8iw20p1.bin
-rw-rw-r-- 1 ubuntu ubuntu 57824 7月 16 18:07 sunxi.dtb
-rw-rw-r-- 1 ubuntu ubuntu 67864 7月 16 18:10 .sunxi.dts
-rw-rw-r-- 1 ubuntu ubuntu 2351698 7月 16 18:07 System.map
-rwxrwxr-x 2 ubuntu ubuntu 276633600 7月 16 18:10 t113_i_linux_evb1_auto_uart0.img
-rw-rw-r-- 1 ubuntu ubuntu 981756 7月 16 16:31 u-boot-sun8iw20p1.bin
-rw-rw-r-- 1 ubuntu ubuntu 5162016 7月 16 18:07 uImage
-rwxrwxr-x 1 ubuntu ubuntu 136244496 7月 16 18:07 vmlinux
-rw-rw-r-- 1 ubuntu ubuntu 62033866 7月 16 18:07 vmlinux.tar.bz2
-rwxrwxr-x 1 ubuntu ubuntu 5161952 7月 16 18:07 zImage
3.烧录固件
拉取打包好的镜像到PC端,打开全志线刷工具 AllwinnertechPhoeniSuit,找到PhoenixSuit.exe ,双击运行。
点击一键刷机。
点击浏览,找到拉取下来的镜像,选择全盘擦除。
选择好之后,不需要其他的界面操作了。这时拿起已经连接好的开发板,先按住 FEL 烧写模式按键,之后按一下 RESET 系统复位键,再松开 **FEL **,就可以自动进入烧写模式并开始烧写。
等待烧录完成,串口打印信息如下:
[27]HELLO! BOOT0 is starting!
[30]BOOT0 commit : 069ed30b88
[33]set pll start
[38]periph0 has been enabled
[41]set pll end
[43][pmu]: bus read error
[45]board init ok
[47]enable_jtag
[49]get_pmu_exist() = -1
[54]DRAM CLK = 792 MHz
[60]DRAMC ZQ value: 0x7b7bfb
[62]DRAM ODT value: 0x42.
[65]ddr_efuse_type: 0x0
[68]DRAM SIZE = 512 MB
[75]DRAM simple test OK.
[82]dram size =512
[85]card no is 2
[86]sdcard 2 line count 4
[104][mmc]: ***Try MMC card 2***
[115][mmc]: mmc 2 cmd 1 err 100
[127][mmc]: ***SD/MMC 2 init error!!!***
[134][mmc]: ***Try SD card 2***
[150][mmc]: 50000000 Hz
[152][mmc]: 3696 MB
[253]Entry_name = u-boot
[260]Entry_name = optee
[264]Entry_name = dtb
[267]mmc not para
[269]Jump to second Boot.
U-Boot 2018.07-g6047f84-dirty (Jul 16 2024 - 16:30:57 +0800) Allwinner Technology
[00.340]CPU: Allwinner Family
[00.342]Model: sun8iw20
[00.345]DRAM: 512 MiB
[00.376]secure enable bit: 0
[00.396]gic: sec monitor mode
SPI ALL: ready
[00.401]line:703 init_clocks
[00.404]flash init start
[00.460]sunxi flash init ok
[00.462]drv_disp_init
[00.509]drv_disp_init finish
[00.520]Loading Environment from SUNXI_FLASH... OK
[00.539]boot_gui_init:start
[00.548]LCD open finish
[00.555]boot_gui_init:finish
[00.564]bmp_name=bootlogo.bmp size 1152054
[00.626]Item0 (Map) magic is bad
[00.629]the secure storage item0 copy0 magic is bad
[00.634]Item0 (Map) magic is bad
[00.637]the secure storage item0 copy1 magic is bad
[00.641]Item0 (Map) magic is bad
[00.672]usb burn from boot
delay time 0
weak:otg_phy_config
[00.683]usb prepare ok
[00.873]usb sof ok
[00.874]usb probe ok
[00.876]usb setup ok
set address 0x20
set address 0x20 ok
set address 0x27
set address 0x27 ok
try to update
[01.281]do_burn_from_boot usb : have no handshake
List file under ULI/factory
[01.292]update part info
[01.295]update bootcmd
[01.301]change working_fdt 0x5c87ce68 to 0x5c85ce68
[01.306][mmc]: can't find node "sunxi-mmc2" try "mmc"
[01.311][mmc]: no mmc-hs400-1_8v!
[01.314][mmc]: no mmc-hs200-1_8v!
[01.317][mmc]: no mmc-ddr-1_8v!
[01.320][mmc]: get sunxi-mmc2 string failed
[01.325]The storage not support sample function
[01.349]update dts
[01.758]no vendor_boot partition is found
ERROR: reserving fdt memory region failed (addr=5c907000 size=3e8000)
[01.806]Starting kernel ...
[01.809][mmc]: mmc exit start
[01.822][mmc]: mmc 2 exit ok
[ 0.000000] Linux version 5.4.61 (ubuntu@ubuntu1804) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Tue Jul 16 16:31:37 CST 2024
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 rootwait init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:riscv@mmcblk0p6:private@mmcblk0p7:UDISK@mmcblk0p8 cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.07-g6047f84-dirty(07/16/2024-16:30:57) mbr_offset=1032192 disp_reserve=4096000,0x5c907000 androidboot.dramfreq=792 androidboot.dramsize=512 mtdparts=<NULL> uboot_backup=ubootA
[ 0.000000] Memory: 467904K/516480K available (7168K kernel code, 425K rwdata, 2572K rodata, 1024K init, 195K bss, 32192K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000204] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000888] Console: colour dummy device 80x30
[ 0.000928] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.001099] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001113] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001760] CPU: Testing write buffer coherency: ok
[ 0.002111] /cpus/cpu@0 missing clock-frequency property
[ 0.002133] /cpus/cpu@1 missing clock-frequency property
[ 0.002145] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002755] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002883] rcu: Hierarchical SRCU implementation.
[ 0.003207] BOOTEVENT: 3.198416: ON
[ 0.003409] smp: Bringing up secondary CPUs ...
[ 0.004649] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.004807] smp: Brought up 1 node, 2 CPUs
[ 0.004821] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.004828] CPU: All CPU(s) started in SVC mode.
[ 0.005356] devtmpfs: initialized
[ 0.019691] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.020311] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.020343] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.021226] pinctrl core: initialized pinctrl subsystem
[ 0.022699] NET: Registered protocol family 16
[ 0.024867] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.066145] rtc_ccu: sunxi ccu init OK
[ 0.068603] ccu: sunxi ccu init OK
[ 0.069134] r_ccu: sunxi ccu init OK
[ 0.109032] sun6i-dma 3002000.dma-controller: sunxi dma probed
[ 0.113709] iommu: Default domain type: Translated
[ 0.113943] sunxi iommu: irq = 24
[ 0.115106] SCSI subsystem initialized
[ 0.115473] usbcore: registered new interface driver usbfs
[ 0.115568] usbcore: registered new interface driver hub
[ 0.116143] usbcore: registered new device driver usb
[ 0.116341] mc: Linux media interface: v0.10
[ 0.116400] videodev: Linux video capture interface: v2.00
[ 0.117735] Advanced Linux Sound Architecture Driver Initialized.
[ 0.118516] Bluetooth: Core ver 2.22
[ 0.118617] NET: Registered protocol family 31
[ 0.118629] Bluetooth: HCI device and connection manager initialized
[ 0.118649] Bluetooth: HCI socket layer initialized
[ 0.118663] Bluetooth: L2CAP socket layer initialized
[ 0.118695] Bluetooth: SCO socket layer initialized
[ 0.118970] pwm module init!
[ 0.129846] g2d 5410000.g2d: Adding to iommu group 0
[ 0.130640] G2D: rcq version initialized.major:250
[ 0.131431] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.133145] clocksource: Switched to clocksource arch_sys_counter
[ 0.143019] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[ 0.157993] thermal_sys: Registered thermal governor 'step_wise'
[ 0.158001] thermal_sys: Registered thermal governor 'user_space'
[ 0.158018] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.158586] NET: Registered protocol family 2
[ 0.159467] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.159500] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.159553] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.159615] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.159720] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.159756] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.159930] NET: Registered protocol family 1
[ 0.162695] Initialise system trusted keyrings
[ 0.162936] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.174068] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.174358] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.174686] fuse: init (API version 7.31)
[ 0.204938] NET: Registered protocol family 38
[ 0.204963] Key type asymmetric registered
[ 0.204972] Asymmetric key parser 'x509' registered
[ 0.205071] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.205087] io scheduler mq-deadline registered
[ 0.205095] io scheduler kyber registered
[ 0.205242] atomic64_test: passed
[ 0.206836] [DISP]disp_module_init
[ 0.207462] disp 5000000.disp: Adding to iommu group 0
[ 0.208093] [DISP] disp_init,line:2372:
[ 0.208098] smooth display screen:0 type:1 mode:4
[ 0.225066] display_fb_request,fb_id:0
[ 0.236835] disp_al_manager_apply ouput_type:1
[ 0.237011] [DISP] lcd_clk_config,line:777:
[ 0.237023] disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(70000000)
[ 0.237023] clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
[ 0.237330] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[ 0.238163] [DISP]disp_module_init finish
[ 0.239563] sunxi_sid_init()783 - insmod ok
[ 0.240322] pwm-regulator: supplied by regulator-dummy
[ 0.242115] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.242464] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.242494] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
[ 1.164971] printk: console [ttyS0] enabled
[ 1.170468] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[ 1.179614] uart uart1: uart1 supply uart not found, using dummy regulator
[ 1.187704] uart1: ttyS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
[ 1.197333] uart uart2: uart2 supply uart not found, using dummy regulator
[ 1.205441] uart2: ttyS2 at MMIO 0x2500800 (irq = 36, base_baud = 1500000) is a SUNXI
[ 1.215051] uart uart3: uart3 supply uart not found, using dummy regulator
[ 1.223084] uart3: ttyS3 at MMIO 0x2500c00 (irq = 37, base_baud = 1500000) is a SUNXI
[ 1.233080] misc dump reg init
[ 1.237157] deinterlace 5400000.deinterlace: Adding to iommu group 0
[ 1.244909] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
[ 1.253914] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 1.261163] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 1.268536] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 1.275987] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 1.282535] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 1.289499] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 1.297255] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=44 assert=1
[ 1.305023] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 1.313159] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 1.320896] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 1.327683] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 1.335243] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 1.343717] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
[ 1.350959] [ADDR_MGT] addr_init: Failed to get type_def_bt, use default: 0
[ 1.358848] [ADDR_MGT] addr_mgt_probe: success.
[ 1.365825] libphy: Fixed MDIO Bus: probed
[ 1.370431] CAN device driver interface
[ 1.375603] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
[ 1.384772] gmac-power0: NULL
[ 1.388104] gmac-power1: NULL
[ 1.391429] gmac-power2: NULL
[ 1.395982] Failed to alloc md5
[ 1.399518] eth0: Use random mac address
[ 1.404424] usbcore: registered new interface driver asix
[ 1.410581] usbcore: registered new interface driver ax88179_178a
[ 1.417528] usbcore: registered new interface driver cdc_ether
[ 1.424158] usbcore: registered new interface driver net1080
[ 1.430568] usbcore: registered new interface driver cdc_subset
[ 1.437292] usbcore: registered new interface driver zaurus
[ 1.443647] usbcore: registered new interface driver cdc_ncm
[ 1.449998] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.457335] sunxi-ehci: EHCI SUNXI driver
[ 1.462284] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.469266] sunxi-ohci: OHCI SUNXI driver
[ 1.474436] usbcore: registered new interface driver uas
[ 1.480485] usbcore: registered new interface driver usb-storage
[ 1.487321] usbcore: registered new interface driver ums-alauda
[ 1.494082] usbcore: registered new interface driver ums-cypress
[ 1.500875] usbcore: registered new interface driver ums-datafab
[ 1.507692] usbcore: registered new interface driver ums_eneub6250
[ 1.514700] usbcore: registered new interface driver ums-freecom
[ 1.521491] usbcore: registered new interface driver ums-isd200
[ 1.528217] usbcore: registered new interface driver ums-jumpshot
[ 1.535136] usbcore: registered new interface driver ums-karma
[ 1.541736] usbcore: registered new interface driver ums-onetouch
[ 1.548665] usbcore: registered new interface driver ums-realtek
[ 1.555477] usbcore: registered new interface driver ums-sddr09
[ 1.562173] usbcore: registered new interface driver ums-sddr55
[ 1.568893] usbcore: registered new interface driver ums-usbat
[ 1.576554] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 1.587610] sunxi-rtc 7090000.rtc: registered as rtc0
[ 1.593463] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:06:05 UTC (365)
[ 1.602551] sunxi-rtc 7090000.rtc: Fail to read dts property 'gpr_bootcount_pos'
[ 1.610884] reasonbase NULL
[ 1.614028] reason large than max, fix to hot reboot, save boot reason
[ 1.621348] invalid reason or reasonbase NULL
[ 1.626256] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 1.632285] i2c /dev entries driver
[ 1.636455] IR NEC protocol handler initialized
[ 1.641540] IR RC5(x/sz) protocol handler initialized
[ 1.649745] usbcore: registered new interface driver uvcvideo
[ 1.656239] USB Video Class driver (1.1.1)
[ 1.660833] gspca_main: v2.14.0 registered
[ 1.665446] sunxi cedar version 1.1
[ 1.669590] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.675945] VE: sunxi_cedar_probe power-domain init!!!
[ 1.681714] VE: install start!!!
[ 1.681714]
[ 1.687305] VE: cedar-ve the get irq is 45
[ 1.687305]
[ 1.693817] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 1.693817]
[ 1.703090] VE: install end!!!
[ 1.703090]
[ 1.708195] VE: sunxi_cedar_probe
[ 1.713464] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.722673] Bluetooth: HCI UART driver ver 2.3
[ 1.727702] Bluetooth: HCI UART protocol H4 registered
[ 1.733772] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 1.741035] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 1.747493] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 1.754075] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 1.754075]
[ 1.762764] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 1.771263] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[ 1.780222] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 1.790139] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 8
[ 1.796381] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
[ 1.802731] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
[ 1.809201] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
[ 1.815666] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
[ 1.822209] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
[ 1.828767] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
[ 1.835324] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
[ 1.841887] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 1.851555] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.862783] sunxi-mmc 4022000.sdmmc: no vqmmc,Check if there is regulator
[ 1.882970] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.907238] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
[ 1.914414] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.924771] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 1.929105] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.935972] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 1.949742] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.953586] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 1.968198] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.971534] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 1.989596] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 1.996063] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 2.002606] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 2.009167] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 2.015727] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 2.021189] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.022737] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 2.031329] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 25000000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.048518] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 25000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
[ 2.048859] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.060434] mmc0: new SDHC card at address 1388
[ 2.071681] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 2.077907] mmcblk0: mmc0:1388 MK 3.61 GiB
[ 2.094611] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.096877] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.123191] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
[ 2.129280] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.133832] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 2.150354] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 2.156619] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 2.162970] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 2.169437] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 2.175898] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 2.182441] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 2.188998] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 2.195554] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 2.202117] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 2.211710] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.222898] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 2.243062] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.267312] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 2.275008] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[ 2.282184] usbcore: registered new interface driver usbhid
[ 2.288470] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[ 2.295369] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.303168] usbhid: USB HID core driver
[ 2.310044] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.311290] exFAT: Version 1.3.0
[ 2.325044] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[ 2.327100] sunxi-msgbox 3003000.msgbox: sunxi_msgbox_probe(): sunxi msgbox start probe
[ 2.334267] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[ 2.342636] sunxi-msgbox 3003000.msgbox: sunxi_msgbox_probe(): sunxi msgbox probe success
[ 2.349892] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[ 2.358877] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver 2.2.1
[ 2.366017] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[ 2.372035] sunxi-rproc 3000008.dsp_rproc: failed to get firmware-name
[ 2.378809] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.386648] remoteproc remoteproc0: dsp_rproc is available
[ 2.403551] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver probe ok
[ 2.411065] sunxi-rproc 6010000.c906_rproc: sunxi rproc driver 2.2.1
[ 2.418676] remoteproc remoteproc1: c906_rproc is available
[ 2.425112] sunxi-rproc 6010000.c906_rproc: sunxi rproc driver probe ok
[ 2.433658] sunxi-rpbuf-controller rpbuf_controller@0: assigned reserved memory node dsp0_rpbuf@42244000
[ 2.449273] NET: Registered protocol family 10
[ 2.455565] Segment Routing with IPv6
[ 2.459756] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.468062] NET: Registered protocol family 17
[ 2.473077] NET: Registered protocol family 15
[ 2.478102] can: controller area network core (rev 20170425 abi 9)
[ 2.485148] NET: Registered protocol family 29
[ 2.490138] can: raw protocol (rev 20170425)
[ 2.494944] can: broadcast manager protocol (rev 20170425 t)
[ 2.501298] can: netlink gateway (rev 20190810) max_hops=1
[ 2.507811] Bluetooth: RFCOMM TTY layer initialized
[ 2.513335] Bluetooth: RFCOMM socket layer initialized
[ 2.519123] Bluetooth: RFCOMM ver 1.11
[ 2.524211] Registering SWP/SWPB emulation handler
[ 2.529978] Loading compiled-in X.509 certificates
[ 2.554633] sunxi-twi 2502800.twi: 2502800.twi supply twi not found, using dummy regulator
[ 2.565135] sunxi:i2c_sunxi@2502800.twi[INFO]: v2.6.5 probe success
[ 2.573933] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
[ 2.581340] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[ 2.624206] get drvvbus-en is fail, 22
[ 2.628414] get ehci0-controller wakeup-source is fail.
[ 2.634445] sunxi ehci0-controller don't init wakeup source
[ 2.640696] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c911a0, 0x:e08e1000, irq_no:3a
[ 2.652702] [sunxi-ehci0]: Not init ehci0
[ 2.657613] get drvvbus-en is fail, 22
[ 2.661819] get ohci0-controller wakeup-source is fail.
[ 2.667793] sunxi ohci0-controller don't init wakeup source
[ 2.674059] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c91450
[ 2.683720] [sunxi-ohci0]: Not init ohci0
[ 2.688615] get drvvbus-en is fail, 22
[ 2.692820] get ehci1-controller wakeup-source is fail.
[ 2.698792] sunxi ehci1-controller don't init wakeup source
[ 2.705057] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c91700, 0x:e08f5000, irq_no:3c
[ 2.717318] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 2.730776] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 2.738056] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 2.748037] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
[ 2.783164] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 2.790975] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[ 2.800467] hub 1-0:1.0: USB hub found
[ 2.804737] hub 1-0:1.0: 1 port detected
[ 2.810002] get drvvbus-en is fail, 22
[ 2.814243] get ohci1-controller wakeup-source is fail.
[ 2.820236] sunxi ohci1-controller don't init wakeup source
[ 2.826503] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c919b0
[ 2.836416] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 2.848750] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 2.856034] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 2.865947] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
[ 2.948017] hub 2-0:1.0: USB hub found
[ 2.952265] hub 2-0:1.0: 1 port detected
[ 2.958190] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
[ 2.972234] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.983438] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.990786] clk: Not disabling unused clocks
[ 2.995721] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.003180] ALSA device list:
[ 3.005536] cfg80211: failed to load regulatory.db
[ 3.008694] No soundcards found.
[ 3.017919] alloc_fd: slot 0 not NULL!
[ 3.026778] EXT4-fs (mmcblk0p5): INFO: recovery required on readonly filesystem
[ 3.035062] EXT4-fs (mmcblk0p5): write access will be enabled during recovery
[ 3.144876] EXT4-fs (mmcblk0p5): recovery complete
[ 3.152655] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 3.161856] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
[ 3.169652] devtmpfs: mounted
[ 3.173193] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[ 3.174658] Freeing unused kernel memory: 1024K
[ 3.203304] Kernel init done
[ 3.206532] Run /init as init process
[ 3.273168] [DISP] fb_free_reserve_mem,line:2316:
[ 3.273174] [DISP] fb_free_reserve_mem wait for sync timeout
[ 3.287007] Freeing logo buffer memory: 4000K
[ 3.374687] hub 1-1:1.0: USB hub found
[ 3.379072] hub 1-1:1.0: 4 ports detected
[ 3.447981] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Populating /dev using udev: [ 3.743916] udevd[1162]: starting version 3.2.7
[ 3.771610] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.781043] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.788442] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.805652] udevd[1162]: specified group 'input' unknown
[ 3.812380] udevd[1162]: specified group 'kvm' unknown
[ 3.849785] udevd[1163]: starting eudev-3.2.7
[ 4.429043] random: fast init done
done
Starting system message bus: [ 4.836615] urandom_read: 3 callbacks suppressed
[ 4.836626] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
[ 4.849986] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
[ 4.900173] random: dbus-daemon: uninitialized urandom read (12 bytes read)
done
Starting network: OK
usb0 current mode: null
[ 6.153157]
[ 6.153157] insmod_device_driver
[ 6.153157]
[ 6.160368] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
device_chose finished!
Starting adb: [ 6.231496] file system registered
OK
init adb main
[ 6.284384] read descriptors
Handling main()
[ 6.288091] read strings
su: unknown user postgres
done
OK
[ 6.432894] FAT-fs (mmcblk0p8): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.475666] sunxi_set_cur_vol_work()422 WARN: get power supply failed
[ 6.488543] FAT-fs (mmcblk0p8): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.522283] android_work: sent uevent USB_STATE=CONNECTED
Starting dnsmasq: OK
[ 6.678764] sunxi_set_cur_vol_work()422 WARN: get power supply failed
[ 6.739147] configfs-gadget gadget: high-speed config #1: c
[ 6.745614] android_work: sent uevent USB_STATE=CONFIGURED
[ 6.773181] sunxi_vbus_det_work()3439 WARN: get power supply failed
[ 6.780440] android_work: sent uevent USB_STATE=DISCONNECTED
swu_param: ####
swu_software: ####
swu_mode: ####
# [ 7.115243] android_work: sent uevent USB_STATE=CONNECTED
# ls
THIS_IS_NOT_YOUR_ROOT_FILESYSTEM opt
bin proc
dev root
etc run
init sbin
lib sys
lib32 system
linuxrc tmp
lost+found usr
media var
mnt
