开发环境搭建
获取TinaSDK源码​
Tina-SDKV2.0源码网盘链接:https://pan.baidu.com/s/13uKlqDXImmMl9cgKc41tZg?pwd=qcw7
D1s-CVBS开发板扩展补丁:https://github.com/DongshanPI/D1s-CVBS_TinaSDK
上传到ubuntu,创建文件夹用来保存源码:
├── tina-d1-h.tar.bz2.00
├── tina-d1-h.tar.bz2.01
├── tina-d1-h.tar.bz2.02
├── tina-d1-h.tar.bz2.03
├── tina-d1-h.tar.bz2.04
├── tina-d1-h.tar.bz2.05
├── tina-d1-h.tar.bz2.06
├── tina-d1-h.tar.bz2.07
└── tina-d1-h.tar.bz2.08
0 directories, 9 files
查看所有文件MD5校验值:
确保校验值对上。否则需要重新上传。
解压源码:
等待一段时间,即可解压完成。
├── tina-d1-h
1 directory, 9 files
ubuntu@ubuntu1804:~/Tina_SDK$ mv tina-d1-h ../
获取扩展支持仓库,然后加以应用:
ubuntu@ubuntu1804:~$ git clone https://github.com/DongshanPI/D1s-CVBS_TinaSDK.git
ubuntu@ubuntu1804:~$ cd D1s-CVBS_TinaSDK
ubuntu@ubuntu1804:~/D1s-CVBS_TinaSDK$ git submodule update --init
ubuntu@ubuntu1804:~/D1s-CVBS_TinaSDK$ cp ./* -rfvd ~/tina-d1-h
编译固件之前,先安装一些依赖,否则编译会报错:
编译出固件​
进入源码目录,执行source build/envsetup.sh、lunch之后,选择3:
You're building on Linux
Lunch menu... pick a combo:
1. d1-h_nezha_min-tina
2. d1-h_nezha-tina
3. d1s_cvbs-tina
4. d1s_nezha-tina
5. t113_100ask_devkit-tina
6. t113_100ask-tina
Which would you like? [Default t113_100ask_devkit]: 3
TINA_TARGET_ARCH=riscv
TARGET_PRODUCT=d1s_cvbs
TARGET_PLATFORM=d1s
TARGET_BOARD=d1s-cvbs
TARGET_PLAN=cvbs
TARGET_BUILD_VARIANT=tina
TARGET_BUILD_TYPE=release
TARGET_KERNEL_VERSION=5.4
TARGET_UBOOT=u-boot-2018
TARGET_CHIP=sun20iw1p1
clean buildserver
[1] 121700
接着make编译、pack打包:
make[5]: Leaving directory '/home/ubuntu/tina-d1-h/target/allwinner/generic/image'
make[4]: Leaving directory '/home/ubuntu/tina-d1-h/target/allwinner/d1s-cvbs'
make[3]: Leaving directory '/home/ubuntu/tina-d1-h/target/allwinner'
make[2]: Leaving directory '/home/ubuntu/tina-d1-h'
export MAKEFLAGS= ;make -w -r package/index
make[2]: Entering directory '/home/ubuntu/tina-d1-h'
Generating package index...
Signing key has not been configured
[2]+ Done $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
#### make completed successfully (26:53 (mm:ss)) ####
PACK_CHIP sun20iw1p1
PACK_PLATFORM tina
PACK_BOARD d1s-cvbs
PACK_KERN
PACK_DEBUG uart3
PACK_SIG none
PACK_SECURE none
PACK_MODE normal
PACK_FUNC android
PACK_PROGRAMMER none
PACK_TAR_IMAGE none
No kernel param, parse it from d1s
copying tools file
copying configs file
storage_type value is 5
rm /home/ubuntu/tina-d1-h/out/d1s-cvbs/image/sys_partition_nor.fex
rm /home/ubuntu/tina-d1-h/out/d1s-cvbs/image/image_nor.cfg
copying boot resource
copying boot file
make user resource for : /home/ubuntu/tina-d1-h/out/d1s-cvbs/image/sys_partition.fex
handle partition user-res
no user resource partitions
APP_PART_DOWNLOAD_FILE = /home/ubuntu/tina-d1-h/out/d1s-cvbs/image/app.fex
Need size of filesystem
no data resource partitions
don't build dtbo ...
update_chip
pack boot package
content_count=3
packing for tina linux
normal
mbr count = 4
partitation file Path=/home/ubuntu/tina-d1-h/out/d1s-cvbs/image/sys_partition.bin
mbr_name file Path=/home/ubuntu/tina-d1-h/out/d1s-cvbs/image/sunxi_mbr.fex
download_name file Path=/home/ubuntu/tina-d1-h/out/d1s-cvbs/image/dlinfo.fex
mbr size = 16384
mbr magic softw411
disk name=boot-resource
disk name=env
disk name=env-redund
disk name=boot
disk name=rootfs
disk name=recovery
disk name=rootfs_data
this is not a partition key
update_for_part_info 0
crc 0 = 8b52d09e
crc 1 = 1eef81c3
crc 2 = 7b597465
crc 3 = eee42538
gpt_head->header_crc32 = 0x33ca0f56
GPT----part num 8---
gpt_entry: 128
gpt_header: 92
GPT:boot-resource: 12000 121f7
GPT:env : 121f8 123ef
GPT:env-redund : 123f0 125e7
GPT:boot : 125e8 175e7
GPT:rootfs : 175e8 233e7
GPT:recovery : 233e8 28b67
GPT:rootfs_data : 28b68 2b367
GPT:UDISK : 2b368 ffffffde
update gpt file ok
update mbr file ok
temp = 20
mbr size = 16384
mbr magic softw411
disk name=env
disk name=boot
disk name=rootfs
disk name=recovery
crc 0 = 8b52d09e
crc 1 = 1eef81c3
crc 2 = 7b597465
crc 3 = eee42538
gpt_head->header_crc32 = 0xa9cea6c4
gpt_entry: 128
gpt_header: 92
GPT:UDISK : 2b368 e8ffde
update gpt file ok
update mbr file ok
[mbr]
mbr_size : 16384 Kbyte
partition_size : 504
boot-resource.fex size : 80K byte
partition_name : env
downloadfile : env.fex
env.fex size : 128K byte
partition_name : env-redund
partition_name : boot
partition_size : 20480
downloadfile : boot.fex
boot.fex -> /home/ubuntu/tina-d1-h/out/d1s-cvbs/boot.img
boot.img size : 7.3M byte
partition_name : rootfs
partition_size : 48640
downloadfile : rootfs.fex
rootfs.fex -> /home/ubuntu/tina-d1-h/out/d1s-cvbs/rootfs.img
rootfs.img size : 9.2M byte
partition_name : recovery
partition_size : 22400
;downloadfile : recovery.fex
recovery.fex size : 24 byte
partition_name : rootfs_data
partition_size : 10240
Begin Parse sys_partion.fex
FilePath: boot-resource.fex
FileLength=14000Add partion env.fex ENV_FEX000000000
FilePath: env.fex
FilePath: env.fex
FilePath: boot.fex
FileLength=74c000Add partion rootfs.fex ROOTFS_FEX000000
FilePath: rootfs.fex
FileLength=920000BuildImg 0
/home/ubuntu/tina-d1-h/out/d1s-cvbs/tina_d1s-cvbs_uart3.img
pack finish
打包成功后,镜像文件保存在tina-d1-h/out/d1s-cvbs/tina_d1s-cvbs_uart3.img
烧录固件​
把镜像文件传到PC端,打开全志线刷工具 AllwinnertechPhoeniSuit,找到PhoenixSuit.exe ,双击运行:
image-20240709111952653
选择一键刷机:
image-20240709112026606
找到镜像路径,选择全盘擦除升级:
image-20240715141718927
选择好之后,不需要其他界面操作,这时拿起已经连接好的开发板,先按住 FEL 烧写模式按键,之后按一下 RESET 系统复位键,就可以自动进入烧写模式并开始烧写。
image-20240709112322292
串口打印信息,如下:
[53]HELLO! BOOT0 is starting!
[56]BOOT0 commit : 88480af-dirty
[59]set pll start
[61]periph0 has been enabled
[64]set pll end
[65][pmu]: bus read error
[68]board init ok
[70]ZQ value = 0x2e
[72]get_pmu_exist() = -1
[74]DRAM BOOT DRIVE INFO: V0.33
[77]DRAM CLK = 528 MHz
[79]DRAM Type = 2 (2:DDR2,3:DDR3)
[82]DRAMC read ODT off.
[84]DRAM ODT off.
[86]ddr_efuse_type: 0xa
[89]DRAM SIZE =64 M
[91]dram_tpr4:0x0
[92]PLL_DDR_CTRL_REG:0xf8002b00
[95]DRAM_CLK_REG:0xc0000000
[98][TIMING DEBUG] MR2= 0x0
[102]DRAM simple test OK.
[105]dram size =64
[106]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
[111]block from 8 to 32
[169]Check is correct.
[171]dma 0x301c8 int is not used yet
[174]dma 0x301c8 int is free, you do not need to free it again
[180]Entry_name = opensbi
[183]Entry_name = u-boot
[187]Entry_name = dtb
▒190]Jump to second Boot.
U-Boot 2018.05-g24521d6-dirty (Jul 14 2024 - 23:47:14 -0400) Allwinner Technology
[00.200]DRAM: 64 MiB
[00.202]Relocation Offset is: 01ee7000
[00.206]secure enable bit: 0
[00.210]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.216]flash init start
[00.218]workmode = 0,storage type = 0
[00.267]sunxi-spinand-phy: not detect any munufacture from id table
[00.273]sunxi-spinand-phy: get spi-nand Model from fdt fail
[00.279]sunxi-spinand-phy: get phy info from fdt fail
defaults:
mtdids : nand0=nand
[00.397]ubi0: attaching mtd4
[00.496]ubi0: scanning is finished
[00.503]ubi0: attached mtd4 (name "sys", size 123 MiB)
[00.508]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[00.514]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[00.520]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[00.527]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[00.532]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
[00.539]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[00.546]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
[00.555]sunxi flash init ok
[00.558]line:703 init_clocks
[00.561]drv_disp_init
[00.582]drv_disp_init finish
[00.584]boot_gui_init:start
[00.588]set disp.dev2_output_type fail. using defval=0
[00.595]boot_gui_init:finish
54 bytes read in 0 ms
[00.727]bmp_name=bootlogo.bmp size 38454
38454 bytes read in 3 ms (12.2 MiB/s)
[00.776]LCD open finish
[00.857]Loading Environment from SUNXI_FLASH... OK
[00.880]out of usb burn from boot: not need burn key
[00.886]Item0 (Map) magic is bad
[00.915]update bootcmd
[00.927]change working_fdt 0x42aa6da0 to 0x42a86da0
[00.961]update dts
noncached_alloc(): addr = 0x42ca5080
noncached_alloc(): addr = 0x42ca50c0
noncached_alloc(): addr = 0x42ca5100
noncached_alloc(): addr = 0x42ca5940
geth_sys_init fail!
[00.981]Board Net Initialization Failed
[00.985]No ethernet found.
[02.377]no vendor_boot partition is found
Android's image name: d1s-cvbs
Detect comp none
[02.395]
Starting kernel ...
▒** 17 printk messages dropped **
Sorting __ex_table...
Memory: 55032K/65536K available (4775K kernel code, 427K rwdata, 1864K rodata, 152K init, 240K bss, 10504K reserved, 0K cma-reserved)
Tasks RCU enabled.
devtmpfs: initialized
cpuidle: using governor menu
rtc_ccu: sunxi ccu init OK
clock: sunxi ccu init OK
sunxi iommu: irq = 4
SCSI subsystem initialized
mc: Linux media interface: v0.10
Bluetooth: Core ver 2.22
Bluetooth: SCO socket layer initialized
pwm module init!
G2D: rcq version initialized.major:251
io scheduler kyber registered
[DISP]disp_module_init
[DISP] parser_disp_init_para,line:1430:
of_property_read fb0_width fail
[DISP] disp_init,line:2386:
disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
display_fb_request,fb_id:0
Freeing logo buffer memory: 1500K
disp 0, clk: pll(306000000),clk(306000000),dclk(51000000) dsi_rate(306000000)
clk real:pll(300000000),clk(300000000),dclk(50000000) dsi_rate(0)
[DISP]disp_module_init finish
uart uart3: get regulator failed
uart uart3: uart3 supply uart not found, using dummy regulator
uart3: ttyS3 at MMIO 0x2500c00 (irq = 21, base_baud = 1500000) is a SUNXI
printk: console [ttyS3] enabled
misc dump reg init
sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
sunxi-spinand-phy: not detect munufacture from fdt
sunxi-spinand-phy: detect munufacture from id table: Winbond
sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
sunxi-spinand-phy: ========== arch info ==========
sunxi-spinand-phy: Model: W25N01GVZEIG
sunxi-spinand-phy: Munufacture: Winbond
sunxi-spinand-phy: DieCntPerChip: 1
sunxi-spinand-phy: BlkCntPerDie: 1024
sunxi-spinand-phy: PageCntPerBlk: 64
sunxi-spinand-phy: SectCntPerPage: 4
sunxi-spinand-phy: OobSizePerPage: 64
sunxi-spinand-phy: BadBlockFlag: 0x0
sunxi-spinand-phy: OperationOpt: 0x7
sunxi-spinand-phy: MaxEraseTimes: 65000
sunxi-spinand-phy: EccFlag: 0x0
sunxi-spinand-phy: EccType: 2
sunxi-spinand-phy: EccProtectedType: 3
sunxi-spinand-phy: ========================================
sunxi-spinand-phy:
sunxi-spinand-phy: ========== physical info ==========
sunxi-spinand-phy: TotalSize: 128 M
sunxi-spinand-phy: SectorSize: 512 B
sunxi-spinand-phy: PageSize: 2 K
sunxi-spinand-phy: BlockSize: 128 K
sunxi-spinand-phy: OOBSize: 64 B
sunxi-spinand-phy:
sunxi-spinand-phy: ========== logical info ==========
sunxi-spinand-phy: PageSize: 4 K
sunxi-spinand-phy: BlockSize: 256 K
sunxi-spinand-phy: OOBSize: 128 B
sunxi-spinand-phy: W25N01GVZEIG reset rx bit width to 1
sunxi-spinand-phy: W25N01GVZEIG reset tx bit width to 1
sunxi-spinand-phy: block lock register: 0x00
sunxi-spinand-phy: feature register: 0x19
sunxi-spinand-phy: sunxi physic nand init end
Creating 4 MTD partitions on "sunxi_mtd_nand":
0x000000000000-0x000000100000 : "boot0"
0x000000100000-0x000000500000 : "uboot"
random: fast init done
0x000000500000-0x000000600000 : "secure_storage"
0x000000600000-0x000008000000 : "sys"
sunxi-ehci: EHCI SUNXI driver
[sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe000736920, 0x:ffffffd004072000, irq_no:31
sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
sunxi-ohci: OHCI SUNXI driver
[sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe000736ce8
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:03:43 UTC (223)
i2c /dev entries driver
[VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
[VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
[VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
[VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
[VIN_WARN]sensor_helper_probe: cannot get sensor1_cameravdd supply, setting it to NULL!
[VIN_WARN]sensor_helper_probe: cannot get sensor1_iovdd supply, setting it to NULL!
[VIN_WARN]sensor_helper_probe: cannot get sensor1_avdd supply, setting it to NULL!
[VIN_WARN]sensor_helper_probe: cannot get sensor1_dvdd supply, setting it to NULL!
gspca_main: v2.14.0 registered
sunxi cedar version 1.1
VE: install start!!!
VE: cedar-ve the get irq is 6
VE: install end!!!
VE: sunxi_cedar_probe
usb 1-1: new high-speed USB device number 2 using sunxi-ehci
sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
ashmem: initialized
exFAT: Version 1.3.0
sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
Segment Routing with IPv6
[SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
[sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000736190, 0x:ffffffd0040f4000, irq_no:2e
[sunxi-ehci0]: Not init ehci0
[sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000736558
[sunxi-ohci0]: Not init ohci0
ubi0: attaching mtd3
random: crng init done
ubi0: attached mtd3 (name "sys", size 122 MiB)
ubi0: good PEBs: 488, bad PEBs: 0, corrupted PEBs: 0
ubi0: available PEBs: 6, total reserved PEBs: 482, PEBs reserved for bad PEB handling: 10
ubi0: background thread "ubi_bgt0d" started, PID 61
block ubiblock0_5: created from ubi0:5(rootfs)
sun8iw20-pinctrl 2000000.pinctrl: pin PB6 already requested by 2500c00.uart; cannot claim for 2000000.pinctrl:38
sun8iw20-pinctrl 2000000.pinctrl: pin-38 (2000000.pinctrl:38) status -22
ERR: id gpio_request failed
vin_csi 5801000.csi: Adding to iommu group 0
sunxi-vin-core 5809000.vinc: Adding to iommu group 0
sunxi-vin-core 5809200.vinc: Adding to iommu group 0
sun8iw20-pinctrl 2000000.pinctrl: pin PE8 already requested by 5801000.csi; cannot claim for 2000000.pinctrl:136
sun8iw20-pinctrl 2000000.pinctrl: pin-136 (2000000.pinctrl:136) status -22
sun8iw20-pinctrl 2000000.pinctrl: pin PE9 already requested by 5801000.csi; cannot claim for 2000000.pinctrl:137
sun8iw20-pinctrl 2000000.pinctrl: pin-137 (2000000.pinctrl:137) status -22
sun8iw20-pinctrl 2000000.pinctrl: pin PE6 already requested by 5801000.csi; cannot claim for 2000000.pinctrl:134
sun8iw20-pinctrl 2000000.pinctrl: pin-134 (2000000.pinctrl:134) status -22
sun8iw20-pinctrl 2000000.pinctrl: pin PE7 already requested by 5801000.csi; cannot claim for 2000000.pinctrl:135
sun8iw20-pinctrl 2000000.pinctrl: pin-135 (2000000.pinctrl:135) status -22
[VIN_WARN]get csi isp clk fail
[VIN_WARN]get csi isp src clk fail
[VIN_WARN]get csi mipi clk fail
[VIN_WARN]get csi mipi src clk fail
[VIN_WARN]Get isp reset control fail
[VIN_ERR]registering ov5640, No such device!
[VIN_ERR]ov5647 request i2c3 adapter failed!
ALSA device list:
#0: audiocodec
alloc_fd: slot 0 not NULL!
VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
devtmpfs: mounted
Freeing unused kernel memory: 152K
UBIFS (ubi0:7): Mounting in unauthenticated mode
UBIFS (ubi0:7): background thread "ubifs_bgt0_7" started, PID 89
UBIFS (ubi0:7): recovery needed
UBIFS (ubi0:7): recovery completed
UBIFS (ubi0:7): UBIFS: mounted UBI device 0, volume 7, name "rootfs_data"
UBIFS (ubi0:7): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
UBIFS (ubi0:7): FS size: 3096576 bytes (2 MiB, 12 LEBs), journal size 1806337 bytes (1 MiB, 5 LEBs)
UBIFS (ubi0:7): reserved for root: 146258 bytes (142 KiB)
UBIFS (ubi0:7): media format: w5/r0 (latest is w5/r0), UUID FE900EA9-D4AD-493A-8674-E58A153B6367, small LPT model
UBIFS (ubi0:8): Mounting in unauthenticated mode
UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 118
UBIFS (ubi0:8): recovery needed
UBIFS (ubi0:8): recovery completed
UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
UBIFS (ubi0:8): FS size: 47738880 bytes (45 MiB, 185 LEBs), journal size 2322432 bytes (2 MiB, 9 LEBs)
UBIFS (ubi0:8): reserved for root: 2254825 bytes (2201 KiB)
UBIFS (ubi0:8): media format: w5/r0 (latest is w5/r0), UUID E1929F41-6C47-4EBE-9816-DF4C22B99EF6, small LPT model
get ctp_power is fail, -22
get ctp_power_ldo_vol is fail, -22
sunxi_ctp_startup: ctp_power_io is invalid.
get ctp_gesture_wakeup fail, no gesture wakeup
gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
sun8iw20-pinctrl 2000000.pinctrl: pin PE11 already requested by 5801000.csi; cannot claim for 2000000.pinctrl:139
sun8iw20-pinctrl 2000000.pinctrl: pin-139 (2000000.pinctrl:139) status -22
wakeup gpio_request is failed
startup:ctp_ops.input_sensor_init err.
can not startup device!
regulator-dummy: Underflow of regulator enable count
gt9xxnew_ts: probe of 2-0014 failed with error -1
Error: Driver 'gt9xxnew_ts' is already registered, aborting...
insmod: can't insert '/lib/modules/5.4.61/gt9xxnew_ts.ko': Operation not permitted
insmod: can't insert '/lib/modules/5.4.61/xr819s.ko': No such file or directory
------run rc.final file-----
: values=on
file system registered
read descriptors
read strings
insmod_host_driver
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
host_chose finished!
------run profile file-----
nice: can't execute '/usr/bin/story_bin': No such file or directory
_____ _ __ _
root@TinaLinux:/#
