添加红外遥控器驱动到LVGL
评测作者:GzMark · 本篇为社区评测文章,来自开发者实测,未经官方逐字校对。
经过前面测试,红外驱动工作正常,这一步准备将红外遥控器加入到lvgl的输入设备中。
前面lvgl的例子里预留了输入驱动部分,这里补上:
#include "irdev.h"
#include <linux/input.h>
#include <stdlib.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/time.h>
#include <limits.h>
#include <unistd.h>
#include <signal.h>
#define DEV_PATH "/dev/input/event1" //difference is possible
static int irfd = 0;
* Initialize the evdev
void irdev_init(void){
irfd = open(DEV_PATH,O_RDONLY);
printf("%d\r\n",irfd);
if(irfd>0){
fcntl(irfd,F_SETFL,O_NONBLOCK);
printf("open ir input ok\r\n");
* reconfigure the device file for evdev
* @param dev_name set the evdev device filename
* @return true: the device file set complete
* false: the device file doesn't exist current system
bool irdev_set_file(char* dev_name){
* Get the current position and state of the evdev
* @param data store the evdev data here
* @return false: because the points are not buffered, so no more data to be read
void irdev_read(lv_indev_drv_t * drv, lv_indev_data_t * data){
static int lastbtn = 0;
static int lasttm=0;
if(irfd>0){
struct input_event ir={0};
static uint64_t start_ms = 0;
if(start_ms == 0) {
struct timeval tv_start;
struct timeval tv_now;
gettimeofday(&tv_now, NULL);
uint64_t now_ms;
if(read(irfd,&ir,sizeof(ir))>0){
if(ir.code){
if(lastbtn != ir.value){
// switch(ir.value){
// case 70:data->key=LV_KEY_UP;break;
// case 21:data->key=LV_KEY_DOWN;break;
// case 68:data->key=LV_KEY_LEFT;break;
// case 67:data->key=LV_KEY_RIGHT;break;
// case 64:data->key=LV_KEY_ENTER;break;
// case 74:data->key=LV_KEY_ESC;break;
// case 7:data->key=LV_KEY_PREV;break;
// case 9:data->key=LV_KEY_NEXT;break;
// default:break;
data->state= LV_INDEV_STATE_PRESSED;
data->btn_id = ir.value;
lastbtn = ir.value;
}else{
if(time_ms>200){
lastbtn = 0;
data->btn_id = 0;
data->state = LV_INDEV_STATE_RELEASED;
}else
if(time_ms>200 && lastbtn){
lastbtn = 0;
data->btn_id = 0;
// data->continue_reading = true;
上面本来想将部分键值注册成导航键,但物理按键,可能都会用到,导航键不一定够,起码我之前的产品用的按键就16个物理按键,所以,这里就不用导航,直接用实际键值,在main.c中注册时,注册为button类型(其实我这里的用法,跳过了输入注册这层,压根没用lvgl的输入设备框架)
main.c中,前面已经加入驱动了,这里就过掉注册驱动
修改前面的test部分代码,让它响应按键
在前面,我初始化界面控件后,开启了一个定时器,主要是来轮询按键(其实这里用法很多,这里用的定时器,还可以做一个界面管理器,有界面管理器去挂输入设备,将键值作为事件给界面管理器当前的界面去处理,不过这里用定时器最方便),下面是定时器事件部分代码:
void checkkey(lv_timer_t * t){
lv_indev_data_t data={0};
curinput->driver->read_cb(curinput->driver,&data);
if(data.state==LV_INDEV_STATE_PRESSED && data.btn_id){
switch(data.btn_id){
case 70:{
//up
const uint32_t c = lv_obj_get_child_id(cur);
if(c>0){
lv_obj_clear_state(cur,LV_STATE_FOCUSED);
cur = lv_obj_get_child(list,c-1);
lv_obj_add_state(cur,LV_STATE_FOCUSED);
lv_obj_scroll_to_view(cur,LV_ANIM_ON);
}else{
cur = lv_obj_get_child(list,lv_obj_get_child_cnt(list)-1);
}break;
case 21:{
// down
if(c<lv_obj_get_child_cnt(list)-1){
cur = lv_obj_get_child(list,c+1);
}else{
cur = lv_obj_get_child(list,0);
}break;
case 68:{
// left
lv_tabview_t* tabview = (lv_tabview_t*)base;
if(tabview->tab_cur>0){
lv_tabview_set_act(base,tabview->tab_cur-1,LV_ANIM_ON);
}else{
lv_tabview_set_act(base,tabview->tab_cnt-1,LV_ANIM_ON);
}break;
case 67:{
// right
if(tabview->tab_cur<tabview->tab_cnt-1){
lv_tabview_set_act(base,tabview->tab_cur+1,LV_ANIM_ON);
}else{
lv_tabview_set_act(base,0,LV_ANIM_ON);
// lv_event_send(base,LV_EVENT_SCROLL_END,NULL);
}break;
这里,模拟了上下左右的导航切换功能
完整的test.c
#include "test.h"
#include "stdio.h"
#include "lv_conf.h"
static lv_obj_t* base ;
static lv_obj_t* list;
static lv_obj_t* tabs[3] = {0};
static lv_obj_t* cur;
static lv_timer_t* timer;
int tabindex=0,listindex=0;
static lv_indev_t* curinput;
case 70:{
//up
if(c>0){
}else{
}break;
case 21:{
// down
}else{
}break;
case 68:{
// left
}else{
}break;
case 67:{
// right
}else{
}break;
void test(lv_indev_t* d){
base = lv_tabview_create(lv_scr_act(),LV_DIR_TOP, 80);
lv_obj_set_size(base,1920,1080);
lv_obj_set_pos(base,0,0);
tabs[0] = lv_tabview_add_tab(base,"Item1");
tabs[1] = lv_tabview_add_tab(base,"Item2");
tabs[2] = lv_tabview_add_tab(base,"Item3");
static lv_style_t style;
lv_style_init(&style);
lv_style_set_bg_opa(&style, LV_OPA_100);
lv_style_set_bg_color(&style, lv_palette_main(LV_PALETTE_BLUE));
lv_style_set_bg_grad_color(&style, lv_palette_darken(LV_PALETTE_BLUE, 1));
lv_style_set_bg_grad_dir(&style, LV_GRAD_DIR_VER);
lv_style_set_text_color(&style, lv_color_white());
list = lv_list_create(tabs[0]);
lv_obj_set_size(list,200,400);
lv_obj_set_pos(list,0,0);
for(int i=0; i<6; i++){
char t[5] = {0};
sprintf(t,"T%d",i+1);
cur = lv_list_add_btn(list,NULL,t);
lv_obj_add_style(cur,&style,LV_STATE_FOCUSED);
curinput = d;
timer = lv_timer_create(checkkey,5,NULL);
void test_quit(){
if(base){
lv_obj_clean(base);
lv_obj_del(base);
上面的修改完成,在lv_ir_test目录下,建立shell,在shell下执行 mm
等待编译完成,将out目录下的lv_ir_test 执行文件通过adb push到板子上
在串口终端下,执行lv_ir_test,此时可以通过红外遥控的上下切换tabview的tab页,通过上下去切换list的选项。
最后呢,可以通过pack打包成镜像,烧录下,此时lv_ir_test 在/usr/bin/下,可以直接在串口终端执行测试
