启动开发板
开发板启动连接接口如下:
image-20250115171457321
接入③12v电源接口、①OTG和②串口。拨动电源开关(亦支持OTG供电,往电源接口方向拨动的是12vDC电源供电,另外的方向是OTG线供电),即可启动开发板。
windows下使用 ADB登录系统​
连接OTG线​
将开发板配套的两根typec线,一根 直接连接至 开发板 OTG烧录接口 另一头连接至电脑的USB接口,开发板默认有系统,接通otg电源线就会通电并直接启动。
安装windows板ADB​
点击链接下载Windows版ADB工具 ADB.7z 下载完成后解压,可以看到如下目录,
adb-tools-dir
adb-tools-dir
adb-tools-windows_config_001
打开cmd连接开发板​
adb-tools-windows_config_003
adb-tools-windows_config_004
C:\System> adb shell
_____ _ __ _
Tina Linux
root@TinaLinux:/#
ADB 也可以作为文件传输使用,例如:
使用串口登录系统​
1. 连接串口线​
QuickStart-01
QuickStart-02
2. 打开串口控制台​
获取串口工具​
使用putty登录串口​
QuickStart-04
使用Mobaxterm登录串口​
Mobaxterm_serial_set_001
3. 进入系统shell​
[27]HELLO! BOOT0 is starting!
[30]BOOT0 commit : 069ed30b88
[33]set pll start
[38]periph0 has been enabled
[41]set pll end
[43][pmu]: bus read error
[45]board init ok
[47]enable_jtag
[49]get_pmu_exist() = -1
[54]DRAM CLK = 792 MHz
[60]DRAMC ZQ value: 0x7b7bfb
[62]DRAM ODT value: 0x42.
[65]ddr_efuse_type: 0x0
[68]DRAM SIZE = 512 MB
[75]DRAM simple test OK.
[82]dram size =512
[85]card no is 2
[86]sdcard 2 line count 4
[104][mmc]: ***Try MMC card 2***
[115][mmc]: mmc 2 cmd 1 err 100
[127][mmc]: ***SD/MMC 2 init error!!!***
[134][mmc]: ***Try SD card 2***
[150][mmc]: 50000000 Hz
[152][mmc]: 3696 MB
[253]Entry_name = u-boot
[260]Entry_name = optee
[264]Entry_name = dtb
[267]mmc not para
[269]Jump to second Boot.
U-Boot 2018.07-g6047f84-dirty (Jul 16 2024 - 16:30:57 +0800) Allwinner Technology
[00.340]CPU: Allwinner Family
[00.342]Model: sun8iw20
[00.345]DRAM: 512 MiB
[00.376]secure enable bit: 0
[00.396]gic: sec monitor mode
SPI ALL: ready
[00.401]line:703 init_clocks
[00.404]flash init start
[00.460]sunxi flash init ok
[00.462]drv_disp_init
[00.509]drv_disp_init finish
[00.520]Loading Environment from SUNXI_FLASH... OK
[00.539]boot_gui_init:start
[00.548]LCD open finish
[00.555]boot_gui_init:finish
[00.564]bmp_name=bootlogo.bmp size 1152054
[00.626]Item0 (Map) magic is bad
[00.629]the secure storage item0 copy0 magic is bad
[00.634]Item0 (Map) magic is bad
[00.637]the secure storage item0 copy1 magic is bad
[00.641]Item0 (Map) magic is bad
[00.672]usb burn from boot
delay time 0
weak:otg_phy_config
[00.683]usb prepare ok
[00.873]usb sof ok
[00.874]usb probe ok
[00.876]usb setup ok
set address 0x20
set address 0x20 ok
set address 0x27
set address 0x27 ok
try to update
[01.281]do_burn_from_boot usb : have no handshake
List file under ULI/factory
[01.292]update part info
[01.295]update bootcmd
[01.301]change working_fdt 0x5c87ce68 to 0x5c85ce68
[01.306][mmc]: can't find node "sunxi-mmc2" try "mmc"
[01.311][mmc]: no mmc-hs400-1_8v!
[01.314][mmc]: no mmc-hs200-1_8v!
[01.317][mmc]: no mmc-ddr-1_8v!
[01.320][mmc]: get sunxi-mmc2 string failed
[01.325]The storage not support sample function
[01.349]update dts
[01.758]no vendor_boot partition is found
ERROR: reserving fdt memory region failed (addr=5c907000 size=3e8000)
[01.806]Starting kernel ...
[01.809][mmc]: mmc exit start
[01.822][mmc]: mmc 2 exit ok
[ 0.000000] Linux version 5.4.61 (ubuntu@dshanpi) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Tue Jul 16 16:31:37 CST 2024
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 rootwait init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:riscv@mmcblk0p6:private@mmcblk0p7:UDISK@mmcblk0p8 cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.07-g6047f84-dirty(07/16/2024-16:30:57) mbr_offset=1032192 disp_reserve=4096000,0x5c907000 androidboot.dramfreq=792 androidboot.dramsize=512 mtdparts=<NULL> uboot_backup=ubootA
[ 0.000000] Memory: 467904K/516480K available (7168K kernel code, 425K rwdata, 2572K rodata, 1024K init, 195K bss, 32192K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000204] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000888] Console: colour dummy device 80x30
[ 0.000928] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.001099] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001113] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001760] CPU: Testing write buffer coherency: ok
[ 0.002111] /cpus/cpu@0 missing clock-frequency property
[ 0.002133] /cpus/cpu@1 missing clock-frequency property
[ 0.002145] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002755] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002883] rcu: Hierarchical SRCU implementation.
[ 0.003207] BOOTEVENT: 3.198416: ON
[ 0.003409] smp: Bringing up secondary CPUs ...
[ 0.004649] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.004807] smp: Brought up 1 node, 2 CPUs
[ 0.004821] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.004828] CPU: All CPU(s) started in SVC mode.
[ 0.005356] devtmpfs: initialized
[ 0.019691] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.020311] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.020343] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.021226] pinctrl core: initialized pinctrl subsystem
[ 0.022699] NET: Registered protocol family 16
[ 0.024867] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.066145] rtc_ccu: sunxi ccu init OK
[ 0.068603] ccu: sunxi ccu init OK
[ 0.069134] r_ccu: sunxi ccu init OK
[ 0.109032] sun6i-dma 3002000.dma-controller: sunxi dma probed
[ 0.113709] iommu: Default domain type: Translated
[ 0.113943] sunxi iommu: irq = 24
[ 0.115106] SCSI subsystem initialized
[ 0.115473] usbcore: registered new interface driver usbfs
[ 0.115568] usbcore: registered new interface driver hub
[ 0.116143] usbcore: registered new device driver usb
[ 0.116341] mc: Linux media interface: v0.10
[ 0.116400] videodev: Linux video capture interface: v2.00
[ 0.117735] Advanced Linux Sound Architecture Driver Initialized.
[ 0.118516] Bluetooth: Core ver 2.22
[ 0.118617] NET: Registered protocol family 31
[ 0.118629] Bluetooth: HCI device and connection manager initialized
[ 0.118649] Bluetooth: HCI socket layer initialized
[ 0.118663] Bluetooth: L2CAP socket layer initialized
[ 0.118695] Bluetooth: SCO socket layer initialized
[ 0.118970] pwm module init!
[ 0.129846] g2d 5410000.g2d: Adding to iommu group 0
[ 0.130640] G2D: rcq version initialized.major:250
[ 0.131431] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.133145] clocksource: Switched to clocksource arch_sys_counter
[ 0.143019] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[ 0.157993] thermal_sys: Registered thermal governor 'step_wise'
[ 0.158001] thermal_sys: Registered thermal governor 'user_space'
[ 0.158018] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.158586] NET: Registered protocol family 2
[ 0.159467] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.159500] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.159553] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.159615] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.159720] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.159756] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.159930] NET: Registered protocol family 1
[ 0.162695] Initialise system trusted keyrings
[ 0.162936] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.174068] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.174358] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.174686] fuse: init (API version 7.31)
[ 0.204938] NET: Registered protocol family 38
[ 0.204963] Key type asymmetric registered
[ 0.204972] Asymmetric key parser 'x509' registered
[ 0.205071] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.205087] io scheduler mq-deadline registered
[ 0.205095] io scheduler kyber registered
[ 0.205242] atomic64_test: passed
[ 0.206836] [DISP]disp_module_init
[ 0.207462] disp 5000000.disp: Adding to iommu group 0
[ 0.208093] [DISP] disp_init,line:2372:
[ 0.208098] smooth display screen:0 type:1 mode:4
[ 0.225066] display_fb_request,fb_id:0
[ 0.236835] disp_al_manager_apply ouput_type:1
[ 0.237011] [DISP] lcd_clk_config,line:777:
[ 0.237023] disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(70000000)
[ 0.237023] clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
[ 0.237330] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[ 0.238163] [DISP]disp_module_init finish
[ 0.239563] sunxi_sid_init()783 - insmod ok
[ 0.240322] pwm-regulator: supplied by regulator-dummy
[ 0.242115] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.242464] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.242494] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
[ 1.164971] printk: console [ttyS0] enabled
[ 1.170468] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[ 1.179614] uart uart1: uart1 supply uart not found, using dummy regulator
[ 1.187704] uart1: ttyS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
[ 1.197333] uart uart2: uart2 supply uart not found, using dummy regulator
[ 1.205441] uart2: ttyS2 at MMIO 0x2500800 (irq = 36, base_baud = 1500000) is a SUNXI
[ 1.215051] uart uart3: uart3 supply uart not found, using dummy regulator
[ 1.223084] uart3: ttyS3 at MMIO 0x2500c00 (irq = 37, base_baud = 1500000) is a SUNXI
[ 1.233080] misc dump reg init
[ 1.237157] deinterlace 5400000.deinterlace: Adding to iommu group 0
[ 1.244909] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
[ 1.253914] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 1.261163] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 1.268536] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 1.275987] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 1.282535] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 1.289499] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 1.297255] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=44 assert=1
[ 1.305023] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 1.313159] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 1.320896] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 1.327683] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 1.335243] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 1.343717] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
[ 1.350959] [ADDR_MGT] addr_init: Failed to get type_def_bt, use default: 0
[ 1.358848] [ADDR_MGT] addr_mgt_probe: success.
[ 1.365825] libphy: Fixed MDIO Bus: probed
[ 1.370431] CAN device driver interface
[ 1.375603] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
[ 1.384772] gmac-power0: NULL
[ 1.388104] gmac-power1: NULL
[ 1.391429] gmac-power2: NULL
[ 1.395982] Failed to alloc md5
[ 1.399518] eth0: Use random mac address
[ 1.404424] usbcore: registered new interface driver asix
[ 1.410581] usbcore: registered new interface driver ax88179_178a
[ 1.417528] usbcore: registered new interface driver cdc_ether
[ 1.424158] usbcore: registered new interface driver net1080
[ 1.430568] usbcore: registered new interface driver cdc_subset
[ 1.437292] usbcore: registered new interface driver zaurus
[ 1.443647] usbcore: registered new interface driver cdc_ncm
[ 1.449998] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.457335] sunxi-ehci: EHCI SUNXI driver
[ 1.462284] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.469266] sunxi-ohci: OHCI SUNXI driver
[ 1.474436] usbcore: registered new interface driver uas
[ 1.480485] usbcore: registered new interface driver usb-storage
[ 1.487321] usbcore: registered new interface driver ums-alauda
[ 1.494082] usbcore: registered new interface driver ums-cypress
[ 1.500875] usbcore: registered new interface driver ums-datafab
[ 1.507692] usbcore: registered new interface driver ums_eneub6250
[ 1.514700] usbcore: registered new interface driver ums-freecom
[ 1.521491] usbcore: registered new interface driver ums-isd200
[ 1.528217] usbcore: registered new interface driver ums-jumpshot
[ 1.535136] usbcore: registered new interface driver ums-karma
[ 1.541736] usbcore: registered new interface driver ums-onetouch
[ 1.548665] usbcore: registered new interface driver ums-realtek
[ 1.555477] usbcore: registered new interface driver ums-sddr09
[ 1.562173] usbcore: registered new interface driver ums-sddr55
[ 1.568893] usbcore: registered new interface driver ums-usbat
[ 1.576554] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 1.587610] sunxi-rtc 7090000.rtc: registered as rtc0
[ 1.593463] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:06:05 UTC (365)
[ 1.602551] sunxi-rtc 7090000.rtc: Fail to read dts property 'gpr_bootcount_pos'
[ 1.610884] reasonbase NULL
[ 1.614028] reason large than max, fix to hot reboot, save boot reason
[ 1.621348] invalid reason or reasonbase NULL
[ 1.626256] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 1.632285] i2c /dev entries driver
[ 1.636455] IR NEC protocol handler initialized
[ 1.641540] IR RC5(x/sz) protocol handler initialized
[ 1.649745] usbcore: registered new interface driver uvcvideo
[ 1.656239] USB Video Class driver (1.1.1)
[ 1.660833] gspca_main: v2.14.0 registered
[ 1.665446] sunxi cedar version 1.1
[ 1.669590] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.675945] VE: sunxi_cedar_probe power-domain init!!!
[ 1.681714] VE: install start!!!
[ 1.681714]
[ 1.687305] VE: cedar-ve the get irq is 45
[ 1.687305]
[ 1.693817] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 1.693817]
[ 1.703090] VE: install end!!!
[ 1.703090]
[ 1.708195] VE: sunxi_cedar_probe
[ 1.713464] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.722673] Bluetooth: HCI UART driver ver 2.3
[ 1.727702] Bluetooth: HCI UART protocol H4 registered
[ 1.733772] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 1.741035] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 1.747493] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 1.754075] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 1.754075]
[ 1.762764] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 1.771263] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[ 1.780222] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 1.790139] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 8
[ 1.796381] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
[ 1.802731] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
[ 1.809201] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
[ 1.815666] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
[ 1.822209] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
[ 1.828767] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
[ 1.835324] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
[ 1.841887] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 1.851555] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.862783] sunxi-mmc 4022000.sdmmc: no vqmmc,Check if there is regulator
[ 1.882970] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.907238] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
[ 1.914414] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.924771] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 1.929105] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.935972] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 1.949742] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.953586] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 1.968198] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.971534] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 1.989596] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 1.996063] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 2.002606] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 2.009167] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 2.015727] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 2.021189] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.022737] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 2.031329] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 25000000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.048518] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 25000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
[ 2.048859] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.060434] mmc0: new SDHC card at address 1388
[ 2.071681] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 2.077907] mmcblk0: mmc0:1388 MK 3.61 GiB
[ 2.094611] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.096877] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.123191] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
[ 2.129280] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.133832] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 2.150354] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 2.156619] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 2.162970] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 2.169437] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 2.175898] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 2.182441] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 2.188998] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 2.195554] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 2.202117] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 2.211710] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.222898] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 2.243062] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.267312] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 2.275008] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[ 2.282184] usbcore: registered new interface driver usbhid
[ 2.288470] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[ 2.295369] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.303168] usbhid: USB HID core driver
[ 2.310044] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.311290] exFAT: Version 1.3.0
[ 2.325044] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[ 2.327100] sunxi-msgbox 3003000.msgbox: sunxi_msgbox_probe(): sunxi msgbox start probe
[ 2.334267] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[ 2.342636] sunxi-msgbox 3003000.msgbox: sunxi_msgbox_probe(): sunxi msgbox probe success
[ 2.349892] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[ 2.358877] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver 2.2.1
[ 2.366017] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[ 2.372035] sunxi-rproc 3000008.dsp_rproc: failed to get firmware-name
[ 2.378809] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.386648] remoteproc remoteproc0: dsp_rproc is available
[ 2.403551] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver probe ok
[ 2.411065] sunxi-rproc 6010000.c906_rproc: sunxi rproc driver 2.2.1
[ 2.418676] remoteproc remoteproc1: c906_rproc is available
[ 2.425112] sunxi-rproc 6010000.c906_rproc: sunxi rproc driver probe ok
[ 2.433658] sunxi-rpbuf-controller rpbuf_controller@0: assigned reserved memory node dsp0_rpbuf@42244000
[ 2.449273] NET: Registered protocol family 10
[ 2.455565] Segment Routing with IPv6
[ 2.459756] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.468062] NET: Registered protocol family 17
[ 2.473077] NET: Registered protocol family 15
[ 2.478102] can: controller area network core (rev 20170425 abi 9)
[ 2.485148] NET: Registered protocol family 29
[ 2.490138] can: raw protocol (rev 20170425)
[ 2.494944] can: broadcast manager protocol (rev 20170425 t)
[ 2.501298] can: netlink gateway (rev 20190810) max_hops=1
[ 2.507811] Bluetooth: RFCOMM TTY layer initialized
[ 2.513335] Bluetooth: RFCOMM socket layer initialized
[ 2.519123] Bluetooth: RFCOMM ver 1.11
[ 2.524211] Registering SWP/SWPB emulation handler
[ 2.529978] Loading compiled-in X.509 certificates
[ 2.554633] sunxi-twi 2502800.twi: 2502800.twi supply twi not found, using dummy regulator
[ 2.565135] sunxi:i2c_sunxi@2502800.twi[INFO]: v2.6.5 probe success
[ 2.573933] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
[ 2.581340] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[ 2.624206] get drvvbus-en is fail, 22
[ 2.628414] get ehci0-controller wakeup-source is fail.
[ 2.634445] sunxi ehci0-controller don't init wakeup source
[ 2.640696] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c911a0, 0x:e08e1000, irq_no:3a
[ 2.652702] [sunxi-ehci0]: Not init ehci0
[ 2.657613] get drvvbus-en is fail, 22
[ 2.661819] get ohci0-controller wakeup-source is fail.
[ 2.667793] sunxi ohci0-controller don't init wakeup source
[ 2.674059] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c91450
[ 2.683720] [sunxi-ohci0]: Not init ohci0
[ 2.688615] get drvvbus-en is fail, 22
[ 2.692820] get ehci1-controller wakeup-source is fail.
[ 2.698792] sunxi ehci1-controller don't init wakeup source
[ 2.705057] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c91700, 0x:e08f5000, irq_no:3c
[ 2.717318] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 2.730776] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 2.738056] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 2.748037] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
[ 2.783164] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 2.790975] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[ 2.800467] hub 1-0:1.0: USB hub found
[ 2.804737] hub 1-0:1.0: 1 port detected
[ 2.810002] get drvvbus-en is fail, 22
[ 2.814243] get ohci1-controller wakeup-source is fail.
[ 2.820236] sunxi ohci1-controller don't init wakeup source
[ 2.826503] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c919b0
[ 2.836416] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 2.848750] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 2.856034] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 2.865947] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
[ 2.948017] hub 2-0:1.0: USB hub found
[ 2.952265] hub 2-0:1.0: 1 port detected
[ 2.958190] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
[ 2.972234] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.983438] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.990786] clk: Not disabling unused clocks
[ 2.995721] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.003180] ALSA device list:
[ 3.005536] cfg80211: failed to load regulatory.db
[ 3.008694] No soundcards found.
[ 3.017919] alloc_fd: slot 0 not NULL!
[ 3.026778] EXT4-fs (mmcblk0p5): INFO: recovery required on readonly filesystem
[ 3.035062] EXT4-fs (mmcblk0p5): write access will be enabled during recovery
[ 3.144876] EXT4-fs (mmcblk0p5): recovery complete
[ 3.152655] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 3.161856] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
[ 3.169652] devtmpfs: mounted
[ 3.173193] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[ 3.174658] Freeing unused kernel memory: 1024K
[ 3.203304] Kernel init done
[ 3.206532] Run /init as init process
[ 3.273168] [DISP] fb_free_reserve_mem,line:2316:
[ 3.273174] [DISP] fb_free_reserve_mem wait for sync timeout
[ 3.287007] Freeing logo buffer memory: 4000K
[ 3.374687] hub 1-1:1.0: USB hub found
[ 3.379072] hub 1-1:1.0: 4 ports detected
[ 3.447981] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Populating /dev using udev: [ 3.743916] udevd[1162]: starting version 3.2.7
[ 3.771610] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.781043] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.788442] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.805652] udevd[1162]: specified group 'input' unknown
[ 3.812380] udevd[1162]: specified group 'kvm' unknown
[ 3.849785] udevd[1163]: starting eudev-3.2.7
[ 4.429043] random: fast init done
done
Starting system message bus: [ 4.836615] urandom_read: 3 callbacks suppressed
[ 4.836626] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
[ 4.849986] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
[ 4.900173] random: dbus-daemon: uninitialized urandom read (12 bytes read)
done
Starting network: OK
usb0 current mode: null
[ 6.153157]
[ 6.153157] insmod_device_driver
[ 6.153157]
[ 6.160368] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
device_chose finished!
Starting adb: [ 6.231496] file system registered
OK
init adb main
[ 6.284384] read descriptors
Handling main()
[ 6.288091] read strings
su: unknown user postgres
done
OK
[ 6.432894] FAT-fs (mmcblk0p8): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.475666] sunxi_set_cur_vol_work()422 WARN: get power supply failed
[ 6.488543] FAT-fs (mmcblk0p8): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.522283] android_work: sent uevent USB_STATE=CONNECTED
Starting dnsmasq: OK
[ 6.678764] sunxi_set_cur_vol_work()422 WARN: get power supply failed
[ 6.739147] configfs-gadget gadget: high-speed config #1: c
[ 6.745614] android_work: sent uevent USB_STATE=CONFIGURED
[ 6.773181] sunxi_vbus_det_work()3439 WARN: get power supply failed
[ 6.780440] android_work: sent uevent USB_STATE=DISCONNECTED
swu_param: ####
swu_software: ####
swu_mode: ####
# [ 7.115243] android_work: sent uevent USB_STATE=CONNECTED
